15” wheels...fit Turbo hubs/brakes?
KLMOTORSPORTS
Fellow builders,
Do 15” wheels fit or is there any modifications (like grind down brake caliper) that have to be done...thanks!
I will be using Turbo hubs/brake setup
Ken
k.rollin
Bruce had to shave his calipers to run 15" Rota wheels, but I have clearance without modifications using 15" König wheels. Neither of us use 2008+ FE5 components as far as I know though.
wombat
I have a SC 07, but just put on the 6UL 15x8 wheels in front. They have about 1/2 inch of clearance. And they are under 12lbs. The 16s that i took off were even closer to the housing.
7602
I have 15” wheels and they fit great...but you are saying you’re going to use the turbo Brembos? Those almost certainly won’t fit under any type of 15” wheel.
