Aftermarket Turbo
Justinreed7
I like anything that goes fast
Driver preference I guess. But once again I talked to ZZP yesterday, keep in mind I want a reliable 300hp that lasts and is cheap, they hands down recommend the LNF. With barely and mods you're getting 300 from a stock 2.0 turbo.
They did say that for big numbers and extreme mods the LSJ is better. But those extreme mods carry extreme price tags.
With the LNF I can run it for 100k miles until it croaks, then I can get a high performance crate motor from ZZP for $1900 and do it all over again.
2008-2010 Cobalt SS is what I'm after, but hey the more of you that pursue the supercharged cars over turbo, the cheaper I can score my model!
Agree 100%. Although a high performance short block starts at 4K. A crate motor for 1900 is just a new stock engine. Although the stock engines can hold some serious power for stock
SinisterSF
The 1900 crate motor is the euro motor, better journals and a few other advantages over the US engine. Not near their super duper engine at all but a great option to making any repairs on a stock motor.
Justinreed7
If you have the LNF or LSJ you don't need a rebuild if you want anything under 450whp. Only the 2.2 and 2.4 guys will need rebuilds for some serious hp.
SinisterSF
I meant a mileage rebuild. Eventually the motor is going to require a refreshing, A full rebuild often costs more than 2k, I'm just saying the crate engine is my answer for that.
TheNuker
What can the base five speed trans handle?
That is what I am wondering also, I'm shooting for an LSJ at 300WHP. I plan to change the clutch and flywheel out but not sure about the transmission. It is the F35 on the 07 cobalt SS LSJ right?
Nuker-
Justinreed7
Nuker-
The f35 transmission is fine with anything below 400whp/400tq. I started having tranny issues when I was launching under boost with drag radials at 500+who. I went through two transmissions in four months then decided to upgrade to the f40 6 speed swap from a 2011 up regal gs. As for the clutch and flywheel, I highly recommend the gmpp clutch from crate engine depot. For the price you simply can't beat it.
For anyone else who might happen on this thread at a later date. The GM recommended after market turbos are:
400-600hp
Borg Warner AirWerks S200 (part number 317222)
Garrett GT 35R
Turbonetics T3/T4 Hybrid
600-1000hp (as if)
Borg Warner AirWerks S400SX, 71mm (part number 177248)
Borg Warner AirWerks S400SX, 74mm (part number 177101)
Garrett GT 40R
and theres more but not even worth posting...
I have also heard good things about the Precision LNF direct replacement turbo, its one of the cheaper options.
http://www.precisionturbo.net/turbochargers/factory-upgrade/details/Factory-Upgrade-Turbocharger---GM-LNF-Equipped-Vehicles/265
For those (like me) planning on an aftermarket turbo set up later on down the road, I have found more good install information on the Polaris Slingshot forums than I ever found on any of the Cobalt forums.
