I can measure my subrrame when I get home from work.
Do you think it's not worth sandblasting and paintingThat's some pretty bad rust going on there. You can buy used subframes on eBay for around $100 and then another $100 or so for shipping.
A powder coat would be nice, but I think it's kind of overkill. That's just me though. I think most of us just rattle can it.
Thanks PHerder & Briann! I appreciate your help!Just measured mine and it is 42 1/8" both dimensions (i.e. square) Sorry to report but it sounds like yours is tweaked.
My first cradle had the ends where the lower control arm bolted on both rusted much worst than what yours shows (i.e. my mounting hole was rusted gone and the PO used a big washer to remount the cradle!
BTW on the last picture at the bottom of the picture, those mounting brackets, that are rusty, are used to mount the stock radiator and are not used for the Goblin... I (and others) just cut them off.
I had the exact same problem on Sunday evening and ended up cutting the nut off and it came off. Just use ear protection, eye protection and a mask, so you don't breath all that stuff in. Also, I had an interesting time dropping the engine without a hoist. I used a floor jack and carefully brought it down to the dolly. It worked well, but I don't recommend it. Great progress guys!10/12/2017 Build video 4 started
I managed to pick up a new subframe yesterday for $200. They had 2 and when I measured the first one, it was very close to mine. Then I measured the 2nd one (from a 2009) and it was exactly 42-1/8" like PHerder and Briann. So if anyone is in the same boat in the future, I suggest you double check measurements before actual purchase - even slightly out of square it looks just fine to my eye with no obvious cracks, broken welds etc. Even better, there was less surface rust (next to none) and we'll definitely be cutting off those pesky shin-digging radiator mounts!
Today we worked our way through build video 4 and a couple things:
1. We found the ABS connector just hanging in the socket - no connection being made. This looks to be the culprit for our early problems on not being able to get the engine starter to turn over with the key right after getting the donor home. Below, the red connector was barely into the socket so no contact. I remember reading somewhere that the ABS had to be communicating for it to start/run so we are fairly confident this was the problem (all other ground connections were good and the only broken wires we could find had to do with the headlights)View attachment 2050
2. We were separating the muffler and ran into some issues. Nuts were a different size than the video said which is not a big deal - the right side we got loose no problem. The left side we put a 2nd and 3rd spraying of PB Blaster and still no luck. Upon closer inspection, what originally looked like dirt/grime on the nut now appears to be welding of some sort - maybe JB Weld? It was getting late, so we called it a night and will try again this weekend. And with a cutting wheel unless anyone has a better idea/recommendation?
I do not know what that is but I can tell you it’s not in my Goblin.10/21/2017 Build videos 6 and 7 are now complete.
We did come across an extra part for us - see picture below. I think it might be a part for the ABS system and thus not really needed for the Goblin but still have to do more research on it.
If its a rocket launcher module, keep it for the Goblin. If not, throw it out.10/21/2017 Build videos 6 and 7 are now complete.
Thanks!Yes, it's the yaw sensor for the ABS. All the wires on it can go.
hahahaha! This and a couple other parts I "may not" need but that rocket launcher will be cool! I knew I had to find something to use that trunk release button on!If its a rocket launcher module, keep it for the Goblin. If not, throw it out.
