3/28/2018 Reorganizing the Wiring Harness #12 Complete and #13 started
Moving along well on wiring now that with the help of several folks, appropriate documentation found!
In #13, our temp sensor wires come from the BCM (documentation says so too) rather than fuse box as mentioned in the video. I guess we will keep them to the side until later in the videos when we can figure out where to route them. Are we the only ones that have seen this?
On the headlight harness, we left the ground lug on instead of cutting off. Overall picture below - the headlight plugs have not been cut off yet.
What we have right now is:
1) ~16" from white fuse block to ground branch with large lug.
2) Headlamp plug (some damage to wires due to donor crash), horn and purple wire coming out about same point. We think the purple is Daytime Running Lamps Headlamp Feed.
3) Downstream from there is a small ground lug branch, then a bunch of ground wires looped with another headlamp connector and an as yet unidentified connector - I think it is a lamp of some sort.
Is this OK for the large ground lug connected to the white fuse block? Or how should we change/fix it?
