Gotcha, thanks!
As far as I know if you paid for the SS kit a heat exchanger is included (the same one Lonny shows). I think I'm going to go a different route with mine and have it in front of my radiator.
I forgot they added the option for the SS kit now, when I ordered it was track or city frame only! Now they have the extended ones, easy entry bars etc.
I played with mounting my heat exchanger to the front when I got it, with the water in and out fittings pointed to the side so the hoses could be run into 90 degree fittings and snake around the side. Pointing them down would have made the hoses speed bump fodder. And the exchanger I had din't really sit well / flat on the side of the rad, so I stuck it behind. If you got a different style heat exhanger, that fit the front better, you could make it look good, and it would cool better
I'm going to have a screen mounted in front of mine so I don't think it will look any different than the stock radiator.
I'm curious to see what you come up with here. The challenge is how do mount it and make it not look goofy. The other thing to consider is the nose cone, you would want that first (if you plan on running one) before you mock everything up so you know it fits.
I'll be running the same cooling mods (E85 as well) and it will be interesting to see how our IAT2's stack up.
I really wish e85 was more available in this area, cuz that's a great way to go. It seems 92 octane and cooling system will really limit the top HP I can squeeze out of this mostly stock LSJ.
I did get the multigauge from aeroforce so I can keep an eye on IAT's. It'll go with the stock boost gauge an AEM wideband gauge I'm going to steal from my skyline now that it's tuned (and I'm going to sell it soon).
The weather will be hot here by the time my goblin is finished, so I'll let you know so we can compare
