Progress report!
Started at the wiring. I decided to to wire in the car rather than bench build as I want to be able to make changes and get a very exact length and placement everywhere. I'm using zip ties instead of tape until I get everything where I want it and most of all...functioning! Once' I'm done, I'll wrap in tape then loom. One such change was the fuse box. I wasn't a fan of having wires sticking out of every side, so I re-routed a couple of the plugs and modified (hacked at) the box as necessary
Now all the wires exit the side facing the valve cover, and will tuck neatly under the box.
I do have a few unknown connectors and wires you guys might be able to help me with. There's a plug with ALL GREEN wires going to it, seen in this photo near the steering column. It's near the OBD port, and I'm not sure if it's necessary.
Also, There's this 8 pin junction plug coming from the blue ECU plug, and 2 wires returning to the front. Not sure where it went?!
Lastly, when I soldered in the 7.5 foot extensions between mega junction plug, I had 3 left over on each side that didn't line up through the plug. the tan and tan/blk twisted pair I know are the data wires that need to be looped in. and I'm assuming I run those to the loose ones coming out of the blue ECU plug.
But the green one I'm not sure about. I did note the pin # on the junction block, which I could reference on a wire diagram.
Here's the loose ones powertrain end. There is a green wire coming from there..
Anyone know a good source for a wiring diagram on a 2007 SS supercharged? I could trace each wire if I had one!
