You keep the AC pump... you can gut the pump part of it, if you want, and just use the front pulley.Just discovered those aren't bolts I snapped off, they were studs that were part of the exhaust manifold/header. So I guess I need a new one. Just as well, this one is rusty as hell and I wasn't looking forward to cleaning it up.
Question; is this an oxygen sensor?
Questions are coming to me hard and fast now ... lol! There's no way I'm going to be able to stick to my self-assigned finish goal of summer 2022. No way!
I have the 2.0L LSJ motor, and in the process of building the Goblin, we remove the AC pump, right?... so do we have to reroute the serpentine belt? (It looks to me like once the AC pump is gone, if we don't reroute the belt, it'll rub against itself on the alternator pulley) .... Also, what length should the new belt be?
I've got a brake boost that I may not be using. I just need to get my frame to see what some of the measurements are to see if an alternate booster will work. If it dose, the one from my donor will need a new home. I know you are still a ways away from assembly and I will likely have my kit delivered before that time, so this may work out okay for both of us.So today, I made it a point that I wanted to have the harnesses all torn out and the dash completely disassembled before I was done. That was a bit too ambitious, but I ALMOST got it all done. All the harnesses are in a pile in the corner of my garage, just waiting for my attention. Not looking forward to that one bit, but I figure I'll hold off on attacking that job until my donor carcass is gone.
The dash was the toughest part of the tear-down for me so far. Unfortunately I was home by myself all day so I had me, myself, and I to move the dash around. I managed, but **** is that thing heavy after a while.
Areas where I may or may not have a problem:
1) I believe I'm going to need a new brake booster. I don't know how these things work so maybe it's an easy fix, but, there's a rod on the inside of the booster that's loose, with a metal "ring" at the end of it. Well, that ring got loose and is floating around inside the booster and I can't get it out. Woops.
2) Clutch pedal ... I tried like hell to get that pedal out late in the day. Couldn't do it. But, I was ready to be done for the day and was irritable and impatient ... got a nice hot shower and sat down to consult Google, and I think I found good instructions to get the pedal loose from the clutch master cylinder. We'll see next time I work on it.
3) There seems to be quite a few little harnesses and plugs that are not accounted for in the instructional videos DF has posted on YouTube. Is it safe to say, "if a particular harness/connector is not mentioned, it's not important"? I've labeled everything I could and didn't snip anything off (except the trunk light connector, woops).
That's all for now...
Since the fuel injector normally runs at 12v, I don't see any issue running it at 9v, as long as you can hear it click, it is working.Testing/cleaning fuel injectors
I pulled the injectors out of my engine last night and was contemplating cleaning them, or at the very least, testing them, and I came across the above video. In it, the guy shows a way to clean the injectors that involves connecting a 9V battery to the injector's leads. Is that really safe for the injector?
