I used a boat battery for this reason. Big sucker filled the whole battery box.Not sure I would want to cut 31 lbs off of the front end!
Nuker-
Maybe I should add a cast iron front wingNot sure I would want to cut 31 lbs off of the front end!
Nuker-
I'm used to having to add weight to make minimum weight for a class, you generally put it where it makes the best difference.Maybe I should add a cast iron front wing
