baustin
Looks like if I go with the 50mm offset for the rear and 45mm on the front then I'll end up with the outer edge of the finished build ~1.2" wider than the front (.6" on each side). Calculated spacer thickness is 0 on the front and 20mm on the rear, which obviously wouldn't clear the studs so I think I'd have to chose a thickness based on minimum to clear the studs. I don't have a measurement on hand right now but I assume 32mm is about minimum. Spacer is because of going 5x110 to 5x114.3. Nothing is ordered on the wheels yet, I might change things up since the offsets push these wheels further out.
(in theory I'd like to be able to tow using my utility trailer to prevent damage but listed as 5x10 the width is under 5' by 1-2" and I'm not sure the goblin can get under that without skinny tires/wheels but then the rear gate is still an issue to figure out)
I'm using info from online that shows the Cobalt front axle track width is 58.7" vs the rear of 58.1", knowing the front of the Cobalt becomes the rear of the new kit car. Not sure if I've decided on the wheels yet or still want to change it up. I need to do some measurements in my garage soon.
