There are a couple pins on the X1 connector that are on a different page, but they aren't the pins we're looking for.
I tried like hell to find that connector myself, but the 3 Malibu’s I found so far had the harnesses cut. That connector is available new but it is $75. Did you splice the wires, or go with new ECM pins altogether? If you went with new pins, what crimper did you use?I got the pin out data from AlldataDIY and confirmed it with some posts I read on HPtuners.
I did make my own PCM connector. I went to the local pick-a-part junkyard and cut one off a Malibu or something... it was the closest thing I could find to the P12 connector and it hooked right in to the PCM.
What year of Malibu are you looking for? I have a 2006 (I believe) on the trailer ready to go to the scrap yard.I tried like hell to find that connector myself, but the 3 Malibu’s I found so far had the harnesses cut. That connector is available new but it is $75. Did you splice the wires, or go with new ECM pins altogether? If you went with new pins, what crimper did you use?
I’m not even sure. It was a month ago I went looking for the connector using heresay info from a website. I do remember it was only certain models. I need an E69 Bosch connector for an LNF PCM. I will likely just buy a new one and re-pin it using the LSJ body harness.What year of Malibu are you looking for? I have a 2006 (I believe) on the trailer ready to go to the scrap yard.
My wife is amazing. She totally understands and supports my crazy hobbies.How did you get permission from the Boss? Or did you believe that asking for forgiveness afterwards would be okay?
Met her in South Korea 8 years ago when I was stationed there.Wow, where did you find her?!? You need to keep her, cause you won't find another one like that!
