Got a TON of work done today.
Rewired my CHMSL brake light to use the #2 windshield wiper relay since I’m using the 2006 fuse box. It is fused with a 15A fuse now and its identical to the factory circuit.
Rewired my BCM blower relay to be a ground switched relay. When key is off, that relay will supply a ground for the motion sensor to activate my courtesy lights by sending a ground signal to the BCM door switch sensing trigger. Since I am using the factory circuit and controls, it will do a soft turn off after 20 seconds. When key is turned on, it will drop that ground and switch off the courtesy lamps. I am using a triple throw dual pole rocker switch which will can turn the lights on, off, or motion only.
I added in the cooling fan wiring to the main harness. I will use a 2 position plug that will connect at the engine harness and the 2 fan power wires will run inside the main body harness.
Changed my switch layout slightly. I will relocate my accessory plug down near the floor. I pinned my factory dimmer wires together at the plug and will instead be using a pwm dimmer switch for all instruments and switches. Still waiting on my info center buttons.
Got a huge order from mouser with all the connectors to do my lighting and cooling fan harness. Every connection on this car will be environmentaly sealed using GM factory connectors.
All I have left to do is add the cooling pump circuit into the engine harness and build in the forward lighting harness. I am hoping I will have enough leftover wire from the rear harness to just use for that; if its not too hot tomorrow I will go out in the garage and start mocking everything up.
