The black plug is for steering wheel controls.Hey Canyon, Mine is the same way.
I need help with these 2 dash plugs. I don't see anything that they plug into.
Please helpzzzz!
Thanks,
Nuker-
The power steering motor wire plugs into the fuse panel by engine.Hey guys,
Can you clarify the power steering wiring. I am not able to find any plug in the harness that connects to the plug on the power steering pump. I checked every connector that I removed and was not able to find the same plug.
Thanks,
Nuker-
Lonny, can you clarify how the info and return button replacements are wired? I have the connector pictured plugged into the steering wheel rotating connector, and the info button plugged into that. My info button and that flat connector both only have four wires and it appears they can be connected directly together.The black plug is for steering wheel controls.
The beige plug is for either boost, hazard, or trunk release. I will check wire color tomorrow and find out.
Or it can be connected directly to the battery. Install 60 amp fuse inline. Is that what you mean?
If you are using the original buttons you can connect matching color to color and it should work.Lonny, can you clarify how the info and return button replacements are wired? I have the connector pictured plugged into the steering wheel rotating connector, and the info button plugged into that. My info button and that flat connector both only have four wires and it appears they can be connected directly together.
Thanks JSATX, Do you have a pic of the other side plugging into the motor itself?
Thanks!
Nuker-
Thanks, so I just leave it as is for now? I already soldered the connector on, just wasn't sure what to do with all the this?I also had this problem just save the wires you are supposed to solder together to the seat harness. Then once you get the buttons from df kit car they will tell you how to wire them to the buttons directly from the harness
Awesome! Thank you!Yeah just wait and they will show you what to do once you get your button setup
