CAN Bus Wires
I think I know the answer to this but I want to make sure before I cut them out. The pink/black and gray/black twisted wires that run from things such as the yaw sensor, steering angle sensor, EBCM, etc are not needed, right? As far as I can tell, they're only related to ABS.
There several threads that mention the CAN bus wires need to be hooked up, but those don't appear to be related to the GMLAN, tan/black and tan twisted pair.
I'm pretty sure I have it right it my head, but I just want to double check.
You can remove every wire that comes from the big yellow airbag plug that hooked to the module located on the tunnel.
