That is from an '09 service manual.
Well guys I’ve got some work done here and there I finally got 3 days off and here’s my progress. I am stuck on the rear coilover mount I think I am missing a piece for it someone let me know I tried calling Adam this morning but no answer I’ll try again tomorrow. And also for brake pads I ordered a front a rear set I guess I messed up there is it just 2 front sets? And the rotors are different?
That aluminum piece is what I’m missing I don’t see it anywhereTwo front brake pad sets are used. I do not have the coil over, but I assume it works the same way. The calipers and pads are the same. The front rotors are slightly larger to give bias to front brakes.
Sweet thanks manYes it just snaps on there, the plastic piece comes off. Mine was also too far over. I cut that back piece off completely from the main shifter bracket. I’ll take some pics in the morning.
Nuker
Where did you get the black shifter ball?Okay well today I got the front wheels to fit and most of the shifter done (waiting on 1 part from Adam and Lonny it will be here tomorrow)
So on the 15x7 enkie rpf1 wheels if you want to run them you will have to grind down your front calipers about 1/4” then static balance the wheel. That was most of my day there just grinding the calipers with a 4” grinder
Installed the new ottp shifter, taillights, wing brackets and cut my down pipe to see how I’m going to run it
It’s a short throw shifter from OTTP with a delrin engraved knobWhere did you get the black shifter ball?
