Waterdriver
MOOG K201285 - RockAutoWhat part number Moog bushings did you use? They look very different than mine.
I had read, somewhere, that these were supposed to be as close to a spherical end as you could get.
Ours was the same way. It was way tighter than 18ftlbs. Surprised it didn't break taking it off.I was just teasing anyhow. Actually I had to wrench really hard on mine to get it off. I ruined the original cap, at least to the point that I didn't want to re-use it. Dang thing was tight!
Glad I asked! Looks like I read the specs wrong and purchased the wrong bushings. I will be ordering the K201285 like yours.MOOG K201285 - RockAuto
Just new rubber. Mine were questionable enough to warrant replacement.Glad I asked! Looks like I read the specs wrong and purchased the wrong bushings. I will be ordering the K201285 like yours.
Is there any reason or advantage to replacing the other bushings on the control arms? i.e. https://www.rockauto.com/en/moreinfo.php?pk=3485115&cc=1440995&jsn=18
Thanks!
If you planning on running a hood, the clutch switch is too high and will hit the hood. Trust me, I know. Check out my the posts on my build. I had to cut it off and remount a different switch. I have another switch if you want to try and do the same thing I did.More small progress.
Brake reservoir, adapters and lines mounted.
Just need a longer hose for the clutch master cylinder.
I saw that on your post and was thinking of doing that same modification.If you planning on running a hood, the clutch switch is too high and will hit the hood. Trust me, I know. Check out my the posts on my build. I had to cut it off and remount a different switch. I have another switch if you want to try and do the same thing I did.
http://dfkitcar.com/forum/index.php?threads/ctuinstras-city-goblin-07-ss-sc-donor.338/page-8#post-8352
No, not really. Wouldn't be hard to use some firm foam or something the help cut down on it. Nobody has really complained about it being too bad.Question, is there something that extends the front bulkhead to the inside of the body to keep the heat from the radiator out of the cockpit?
I don't think you could get those too much closer!Worked on the dual pass plumbing.
Hope the lines are tucked close enough in towards the engine, for fuel tank clearence.
That is my plan. Engine coolant fan will run through low fan relay controlled by ECM and intercooler fan will run off the other fan relay which will be constant ground trigger to run full time with key on.SC Intercooler fan question. What are people using for the fan power source?
Existing radiator fan circuit?
Are you having to program the constant ground trigger in the ECU for the intercooler fan or is that circuit already configured that way?That is my plan. Engine coolant fan will run through low fan relay controlled by ECM and intercooler fan will run off the other fan relay which will be constant ground trigger to run full time with key on.
The ECU usually provides the ground for the 86 pin of the relays to tell the fans when to turn on. I will just be grounding the 86 pin of the second relay right from the fusebox to ground instead of it going to the ECU.Are you having to program the constant ground trigger in the ECU for the intercooler fan or is that circuit already configured that way?
I'm thinking of running dual heatexchangers, each with their own fan. I don't know off hand how much current draw the fan is but thinking I can power both from the same circuit. They're pretty small fans.
Awesome, thanks! I think I'll be doing the same.The ECU usually provides the ground for the 86 pin of the relays to tell the fans when to turn on. I will just be grounding the 86 pin of the second relay right from the fusebox to ground instead of it going to the ECU.
I thought the same. A few people are running the stage 3 one from zzp. I am going to go with the provided one first and see how it goes.Awesome, thanks! I think I'll be doing the same.
The heatexchanger seems small in cooling capacity compared to the stock Cobalt one and the ZZP version.
Anyone running the provided heatexchanger noticing any heatsoak when driving for awhile or getting any coolant temp readings for Intercooler system?
