Lethalcast
I noticed they put one of each tire for the front and back going the wrong direction. I'm not sure how much it will matter but they are directional.
Where did you get the connector that goes on the steel braided hose on the valve cover to the brass fitting near the MAF? I will have to check I did not notice any in the wrong direction. Maybe swapped sides considering they are the same size tires/rimsHere is some different pics of the cold side for youView attachment 6645View attachment 6646View attachment 6647View attachment 6648. View attachment 6644
Yea it looks to be solely mechanical, my kit supplied tab seems to be placed correctly but nothing happens as the tab swipes the switch ??? Either way very minor issue. Drove my cobalt for years self cancelling hahaThe cancel I believe is a mechanical thing and shouldn't matter if the car is on or not.
I see what you are referring to, it took a minute. Thank you! I was wondering if that would clear the hood..Man I really hate to bring this up but it looks like your power steering unit it mounted wrong. The top L-shaped bracket should be turned around where the bracket is closer to the driver and the "L" part is facing forward. This will also change the clock of the entire unit.
Also take a photo of the cancel unit and how you have it mounted with the steering wheel straight. It's easily mounted wrong also.
