aaronbuley
having trouble bleeding the clutch. here's the situation... would love your thoughts.
yeah, i saw that post, thank you. i remounted my reservoir to the top 2 holes (making it level), and i know there's fluid making it to the clutch because it's pulling it through that first hose before it hits the clutch cylinderAre you sure you are getting fluid to the MC? See my post about the reservoir fluid level.
http://dfkitcar.com/forum/index.php?threads/warning-clutch-fluid-level.858/#post-14243
correct. see the play in the pushrod at the beginning of the video, i'm thinking that's a problem and why it's not pumping anything through.So no fluid comes out with the clutch line disconnected and you manually pump the clutch pedal?
yeah thanks, saw that too, but i can't even get fluid to flow through the master cylinder to get to the hard linesDid you check to make sure your hard line isn’t clogged? From the MC to the trans. Saw a post earlier about someone’s hard brake lines from DF had blockage in them. Just a thought.
!Fixed it!
