Torchandregdoc
I am using a 09 HHR SS as a donor and want to make sure the HHR rack and pinion will work in the Goblin. Can someone verify that the angle of your pinion shaft is relatively similar to the angle of mine?
Yeah, I chuckled when I first read that too. Double-Entendre."Does my rack look like your rack?"
I'll bet that has a different meaning on other forums!
I found the fusebox was a little floppy, so i added a strap on the back that goes to the engine, and to my fuel filter. Up to you!While I have your attention, can I cut the bottom off of my fuse /breaker box?
Good info. Maybe I'll leave it on for a bit.I found the fusebox was a little floppy, so i added a strap on the back that goes to the engine, and to my fuel filter. Up to you!
