Motoracer110
Was curious if the kit comes with new rotors?
Thank u
Thank u
What did you do about brake pads ? Is it just two sets of front pads ?I had a kit for an SS/SC donor, and it came with (4) new rotors and calipers.
You wouldn't happen to know if the 5x114.3 and 4x100 are different would you ? I am doing the 4x100 conversion.For the SC DF Kit Car provided calipers, you can use Duralast DG956 brake pads for both the front and rear.
Side note, this pads are a little touchy and like to grab until you put a little heat in them.
I think they are all the same. I have the 4x100 set up and have re drilled 5 bolt rotors.You wouldn't happen to know if the 5x114.3 and 4x100 are different would you ? I am doing the 4x100 conversion.
I bought Centric Posi Quiet Premium Ceramic pads from https://www.carid.com/ Front brake pads for 2009 Cobalt base model | 39.49 |
Rear brake pads for 2009 Pontiac Solstice | 31.53 |
