There is also this method. It talks about brakes but the clutch is done the same way.I bled mine via gravity and air pressure at the master cylinder resevoir.
I attached a long piece of clear vinyl hose to the bleeder to a catch can. Opened the bleeder screw.
Let gravity begin to do its work and watch the fluid level begin to drop in the reservoir. Filling to keep level full.
Once it stopped moving, applied lung pressure to the reservoir opening until fluid was coming out of bleeder screw hose.
Closed bleeder screw.
At that point I could start pumping the the pedal at start feeling pressure build.
Then proceeded with normal bleeding process to remove any additional air bubbles.
All brake lines were bled via gravity as well. Some puffs on the reservoir to help speed things along.
http://dfkitcar.com/forum/index.php?threads/bleeding-brakes-the-easy-way.565/#post-7703
