That is correct! They went to a Socket head cap screw over machining a button head down.This is where that one goes.
No problem man... and you look a lot different in person than your photo. ha ha.Looking good, appreciate you letting me stop by to check it out.
They bottoms should have come in the kit. Check with Adam.Build is going slow since im waiting on parts to be shipped... but i did end up designing and 3d printing an adapter to hold the ebay side mirrors with blinkers on. This is only temporary until i get some real ones machined.
At least the problems are consistent. Now I feel better in out build that it wasn't just me doing something wrong. We also ran into that same issue. You will have to grind or cut away part of the clutch pedal for it to clear the steering shaft. That's what we did.Something's not looking up... i can't connect my clutch pedal. It hits the steering shaft and the holes don't line up. Unless I'm doing something wrong
