Exhaust gasket
Tim Moland
Is there a gasket that goes between the turbo header and the DF exhaust, or does it just butt up against it?
Tim Moland
Ok. I'm probably just overlooking it. I was thinking of a full flange gasket. I'll check when I get home tonight.
Christopher Sanchez
There will be small circle exhaust gasket that you can reuse. Most likely it’s still attached to your turbo side. Mine was.. this is the only gasket you need
So it takes one of these at the outlet of the O2 housing?
My downpipe had the LNF Downpipe Gasket, not the o-ring gasket.
