BAR-AIR
Has anyone considered welding in a slightly thick are steel floor (and back wall) into their kit. To replace the aluminum floor (wall) that is supplied with the kit. Reason that I’m asking, had to remove my seats while I was installing the emergency brake handle and even with the small amount weight on the floor I started to separate the sealant between the tube and the flooring. Also on entering the car even with the bar stock under the floor there is a lot of flex to the floor in that area (and I’m only 170#s). The more that I look at it the more that I wish I would have.
