Did you have to send them a template to make the mats from?Check out https://www.cocomats.com/ I have a set, and they are awesome. Will run you about $200 for both sides.
For a better visual of Brian's mats see post #188 in this thread:Yes. Took me about 15 minutes to measure and cut one out of poster board. You only need one template because one side will be drivers, and the flip side will be passenger's side.
Very nice!So I made some custom floor mats. It’s a thin aluminum plate, with some industrial rubber-backed entry mat glued to both sides. Nice and easy to remove and vacuum/clean.
Thanks. It works for me.That actually looks pretty good. The thing I like about yours more is the sharp corners. Mine are rounded off.
It helped keep it rigid and in place.I used that same carpet mat. I think it looks good with the stripes running in it. I may have to steal the aluminum sheet idea.
Thanks. I did see the black rubbery material as well, but decided on the carpet. A little less “industrial” and a little more “home comfort”. LmaoI like them. We used a rubber material and it's been working well, but I like the comfortable look of that material.
