jirwin
Can someone take a picture of their frame where the radiator tubes exit the frame at the front? I think my frame is messed up and is missing the front holes pictured here:
Mine is N/A, so that shouldn't be a problem. I'm genuinely confused though. Here is what I am working with...Video was spot on except for the frame change. If your building an ss/sc consider mounting your heat exchanger before your radiator it was sorta difficult to work around.
Which side of the car is hot and which is cold?I used two of the top hoses Dayco 71796 in your first picture. used them for top and bottom hoses in the front. I did the reverse flow on my car. Hot water in the top of radiator cold out of the bottom. So even if I get a air pocket I still have coolant flow. 600+ miles no issues.
I added to my last post.Which side of the car is hot and which is cold?
