The headlight harness needs the ground wire connected to start the car.
What is required to run the headlights, turn signals & horn?
1. There is a connector to join the headlight harness to the body harness, but only 2 wires are left on it (Green with white stripe, and yellow with a black stripe). Edit: The 2 missing wires were part of the SRS - I eliminated the front impact sensor which went back to this connector.
Do I leave this connected to the body harness?
2. Is there documentation for the headlight harness?
Do I cut open the headlight harness, and find the wires I need with a meter?
I don't need the SRS impact sensor, window washer pump, and do I keep that last thing (GM 15035785 air temp sensor)?
Do all the lighting wires need to be extended all the way thru the center tunnel to the front headlights,
and therefor need to be included before wrapping up the harness?
I'm surprised I can't find this on the forum... I must be using the wrong search key words...
