Heat exchanger fan wiring
Before thinning you body harness locate pin D7 on the big red BCM plug. There should be two pink wires coming from it.
One of the wires goes to the passenger seat plug. The other goes to the inflatable restraint module plug.
Cut these two wires about an inch from the big red plug and solder on a two foot length of wire. Some of your rear speaker wire works well for this.
If you have already cut these wires off at the big red plug you will need to remove the connector from the plug and attach a wire.
Use a small screwdriver to push down the lock tab and remove the blue retainer.
Now use a small screwdriver to release the connector.
Pry open the tabs holding the pink insulation and remove the insulation to expose the wire. Solder a two foot long piece of rear speaker wire to the exposed wire.
Cover with heat shrink.
Reinstall connector and retainer.
Attach this wire to your heat exchanger.
ncgoblin
Use a small screwdriver to push down the lock tab and remove the blue retainer.View attachment 5256
View attachment 5258View attachment 5259
Reinstall connector and retainer.View attachment 5262View attachment 5264View attachment 5263
I had a single smaller gauge wire will this be sufficient enough to power the fan?
Thanks
That is a 10A circuit. The heat exchanger fan pulls ~4A. I'm using 20 AWG with no issues. As long as your runs are short there is really no need to run a huge wire. 20 AWG is good for approximately 15A.
