How to deal with cut subframe
#1
Hi all,
I had a fight with my passenger side control arm rear bolt 200k miles in salty Canadian winters, I actually feel like I got off easy). The bolt snapped and was very seized in the bushing sleeve. To separate the subframe from the frame (and from the seized sleeve/bolt) I cut the subframe to get my cut off wheel in and cut the sleeve/bolt. It worked, but now I need to figure out what to do about the subframe. I think main options are (and I'm open to better ones!):
1. Mig weld the folded piece back in (recognizing that I'm a very novice welder and that steel is about the very top end of what my welder can do)
2. As above, plus weld a 1/8 plate over the area to reinforce it (I worry the extra thickness might through off steering/suspension geometry?)
3. Buy a (relatively) intact junkyard subframe (probably like C$120 or so)
I really want to do #1 or #2 but don't want to set myself up for a catastrophic failure.
Thanks for the feedback!
Here's a pic of what I'm working from:
#2
Without a doubt buy one. Even if I were a master welder I wouldn't want to have any chance of a weak spot on a part as crucial as that.
RichRich
Not sure what donor you are using but you can use a subframe from any model and year cobalt. Only difference will be the mount for the sway bar.
#8
Awesome, thanks! I love that our forum has that info and sorry I missed it. I kept researching and post #2 in this CobaltSS thread: https://www.cobaltss.net/forums/suspension-67/upgrading-fe1-fe5-319672/, suggests that you could just drill a second hole in the FE1 or FE3 engine cradle to mount the 2 bolt sway bar clamps from the FE5. I think I've got a line on a reasonably cheap local FE5 cradle, so I may not have to find out if that's right.
RichRich
sweet, always easier if you can get a matching part. I was thinking about welding it on, so could too that route as well if it doesn't work out.
