How to deal with cut subframe
Jonathan O'Hara
Hi all,
I had a fight with my passenger side control arm rear bolt 200k miles in salty Canadian winters, I actually feel like I got off easy). The bolt snapped and was very seized in the bushing sleeve. To separate the subframe from the frame (and from the seized sleeve/bolt) I cut the subframe to get my cut off wheel in and cut the sleeve/bolt. It worked, but now I need to figure out what to do about the subframe. I think main options are (and I'm open to better ones!):
1. Mig weld the folded piece back in (recognizing that I'm a very novice welder and that steel is about the very top end of what my welder can do)
2. As above, plus weld a 1/8 plate over the area to reinforce it (I worry the extra thickness might through off steering/suspension geometry?)
3. Buy a (relatively) intact junkyard subframe (probably like C$120 or so)
I really want to do #1 or #2 but don't want to set myself up for a catastrophic failure.
Thanks for the feedback!
Here's a pic of what I'm working from:
Dreamer
Without a doubt buy one. Even if I were a master welder I wouldn't want to have any chance of a weak spot on a part as crucial as that.
RichRich
Not sure what donor you are using but you can use a subframe from any model and year cobalt. Only difference will be the mount for the sway bar.
Jonathan O'Hara
All right, thanks for the feedback guys, to the junkyard I go to get a replacement, especially since they seem reasonably cheap, like C$100 - C$150.
Jonathan O'Hara
My donor has the FE5 "performance ride" suspension. What are the differences in mounting the sway bar to the subframe, and will they be a problem?
RichRich
sweet, always easier if you can get a matching part. I was thinking about welding it on, so could too that route as well if it doesn't work out.
