So what is the competition to HP Tuners?
Trifecta?
HP Tuners Pros/Advantages:
- cheaper than using a replacement ECM/PCM like Holley Dominator EFI Vehicle Management Systems
- allows for engine tuning for most aftermarket power adders.
- You can tune multiple engines with the purchase of additional credits.
Cons/Disadvantages:
- need to buy a wide-band MAP sensor, MVPI2 and 2 credits.
- large learning curve... or hire an expert.
- limited to the capabilities of the stock GM ECM
(what are these? only 1 fuel rail? Or can you add methanol injectors too? What about adding nitrous? )
- limited to the portion of the GM ECM that HP Tuners has successfully hacked into.
Which wide band would you get for the SC engine? You would need at least a 2 bar one, but which one?
Which wide band would you get for a Turbo engine? A 3 or 4 bar one?
Does it support a replacement dash screen, with programmable guages?
Is there much to be gained by tuning the stock engine?
I've watched a
bunch of videos about HP Tuners, but I still have a lot to learn.
