I believe so.What size is most of the wiring? 22-18? What is a good estimate to start with?
I understand, I am an electrical engineer myself, but if you have corroded wire you should clean it regardless of what you use. I have not had any problems with them thus far. We use them a lot on mud buggies that get submerged and so far so good. Guess it is just a matter of what your comfortable with.I tried those, but they can leave questionable joints especially if your wiring is corroded. But then again, I have high standards for solder joints. I was trained in the AF with NASA standards.
You will have extra clean fuel.According to Lonny the TC's have a built in fuel filter that is installed in the fuel pump. No need for an external one. You just need to run a single line from the pump to the inlet on your intake. I did not know this at the time so I installed an additional one. So filtered fuel is filtered for me.
