If I looked it up right, it should be the right most one which is for your park lamp control. Pin 8. The other two go to the doors.
See below 6,7,8.Accidentally cut the wrong white wire. Anyone know which of these three wires I need to solder back on?
Do you have a picture of the front of the large connector? Also if you check continuity from the pins to the BCM or ECM I can look it up.Well just working through 11 Part 1.......
I am pretty sure i goofed up somewhere along the way......I must have removed the light blue wire from the center brake light. Either I can find out where it comes from or just tap in and add a wire later if I chose to have a third brake light. Either way, whoops.
The second issue is that I could not find a batter voltage connector. This is the Black/Grey/White plug. Did these come on TC cars? Assuming so and also assuming I shouldnt have cut it out.....
Last but not least, the answer might be in the next video or two but are these supposed to still be connected?
This was the one part of the build I knew I would not like...lol. It is nerve racking to cut stuff out.....but I am enjoying getting it all cleaned up and put back together.
Trying to get my wife to take a picture of it.....Im at work. The orange and yellow wires went to the main airbag plug.Do you have a picture of the front of the large connector? Also if you check continuity from the pins to the BCM or ECM I can look it up.
Battery Voltage connector:Well just working through 11 Part 1.......
Good question I cannot seem to find where it plugs up I would have thought at the negative battery cable but I do not have a sensor for it.Wdoes the battery voltage connector get plugged into on the car?
You are correct, my naming was off. Thanks!The TCs don't have a battery current sensor if that's what you mean by voltage connector. Not sure if I'm on the same page.
Just quoted you^^^^^ Appreciate the help Brian, if you beat me to it I will track down my reservoir(hoping I still have it....lol.....I cant picture where it is in the garage right now) and see if it plugs in.Don't quote me on this yet since I'm not at home, but I want to say the green/black connector is either your ambient air temp sensor or the coolant tank reservoir.
