IDRVSLO / TRACK / 08 SS TC **REGISTERED** #105
This is just me, but you're still at a point where it's still easy enough to just pull the harness out and fix anything that is too short or long.
IDRVSLO
Yeah I can simply fix it in there. I had no additional room to move those left or right before I taped up. The only fix would be to extend them.
jamesm
I had the exact same issue with the tunnel grounds not lining up with the existing stud. I just put another bolt in and moved on.
IDRVSLO
Just moving along, got the clutch pedal in, then installed that tubing(forgot the car in the video was an auto). It was kind of a pain but I made it. The clutch pedal clears with no modifications. Hoping the wiring is good to go because I am putting it together like I am not taking it back apart.
Lethalcast
You're gonna need some grip tape on that kick panel to keep people from damaging that beautiful kick plate lol
IDRVSLO
Nothing really new to report, spent the weekend organizing, tearing down my wire harness table and getting the car in a position to finish the build from.
Just bolted her in last night, does the pump orientation look good?
I think the float raises toward the passenger side.
Correct. Make sure the float doesn't catch the baffle in the tank otherwise it won't work. I should bend my float rod some more. It shows full for a very long time and then runs out quickly.
IDRVSLO
Flipped the pump and also trimmed that tab. I wanted to rotate the connector a bit more to go directly between bolts.
