I'm pretty sure they should all be the same size.
So just out of curiosity I pulled the 12mm bolts out and threaded the 14mm right in... I pulled both 12mm bolts out and they are both different. you can see in the attached photo the 14mm bolt is the far right one. the 2 on the left are from the caliper... I think I am going to just go buy some 14mm bolts so they all match. is that a good Idea? from what I can tell from the boxes there is 2 for the left side and 2 for the right side.I'm pretty sure they should all be the same size.
I've realized through this project that there is a difference in bolt head size vs bolt size depending on if the bolt is JIS standard or ANSI/ISO. I have a lot of JIS bolts from Japanese sportbikes and the same size bolt takes a different wrench on some of them vs. the stock Cobalt stuff.Also, I have found out that a bolt from a hardware store might have a different head size than the factory bolt despite having identical bolt diameters.
Just a FYI if you go ask for 14 mm bolts they will never fit the hole. Bolts are measured by the thread size not the head size. I think those are 8mm bolts.So just out of curiosity I pulled the 12mm bolts out and threaded the 14mm right in... I pulled both 12mm bolts out and they are both different. you can see in the attached photo the 14mm bolt is the far right one. the 2 on the left are from the caliper... I think I am going to just go buy some 14mm bolts so they all match. is that a good Idea? from what I can tell from the boxes there is 2 for the left side and 2 for the right side.
In my opinion, if you can't afford for it to come loose, Loctite it. I would red loctite the stud to the hub, or at least blue Loctite. If the nut isn't a lock nut, which I believe it is, then I would Loctite it also.Am I supposed to loctite these 4 bolts?
