Yes throttle body responds to foot pedal. I’ll try thatDoes your throttle body respond to the accelerator pedal?
I agree with Hokie, check your grounds. Grab a heavy gauge wire and attach one end to your negative battery post. Touch the other end to each of your grounds lugs and listen for clicks or anything changing.
Has the small stock lcd screenDid your goblin have a boost gauge or an LCD screen?
Yes should it turn on with key?Is your LCD screen hooked up?
Yes it’s hooked up.I am not sure when it should come on but I know that it will not run if the LCD screen is not hooked up.
I did it for the fuel pump and the pump runs, I will try the same for starter relay tomorrow. I’ll update you thenPull out your fuel pump relay and use a jumper wire to see if the fuel pump will run, also do the same for the starter relay.
Somewhere in our teatdown videos we show how to use a jumper wire to empty the fuell tank.
Will the bolts stop moving when tight?I had similar issues. One thing I found was that my floor strap wasn't really grounding at all. I used jumper cables to run it to the negitive battery. Then from the throttle to the engine. Make sure your fuse box 7mm bolts are tight as well.
Yes! Unless they are stripped out. The bolts draw the connectors down tight. If the bolts are right and just spin, they haven’t started into the threads and not even close to making connection. You may have to push i down firmly while tightening them.Will the bolts stop moving when tight?
Probably my issue then because all the bolts as of right now just spin... Yes! Unless they are stripped out. The bolts draw the connectors down tight. If the bolts are right and just spin, they haven’t started into the threads and not even close to making connection. You may have to push i down firmly while tightening them.
I had a similar issue on my first donor (09 SS TC) that I worked on.Got it all tightened down correctly. Still no start.. I tried bypassing relay to fuel pump.... fuel pump primes.... I bypassed crank relay and it cranks. I also took a cable directly from ground and on battery and touched all ground cables and listened for relays or any change and didn’t hear anything. Going to jump back in the forums and check out some other peoples issues on start. When I turn the key I’m not getting the fuel pump to prime...
I've also got Illusion Purple, there's a fair number of pics in my thread. Page 6 is where the color starts.do you have any pictures of your goblin in direct sunlight. I am looking at the illusion purple as one of my choices... and would like to know if yours is a base plus anything. i am looking at going a 3 stage powdercoat and trying to get an idea what it will look like
