Jlarson524
What are people using for adjustable seat brackets for the Corbeau seats supplied from DF?
The DF optional brackets have three position adjustment I believe, otherwise you will have to create your own. We used the donor adjusters and made an adaptor plate.
ctuinstra's City Goblin - 07 SS/SC donor **Licensed**
Anyone know for sure which passenger side set of holes to mount the SS/SC engine? I haven't been able to find this information and it seems it would work in either. And I can't tell well enough by eye-balling it which is the correct hole. The angle of the picture is off a bit, they line up...dfkitcar.com
Kaleb picked up the frame from the powder coater this afternoon. Now, let the build begin!dfkitcar.com
I'd have to have Kaleb check with his old HS teacher. He's moved on to college but might be able to see if they can cut and bend another set. He sold one set last year for $50 for the stainless steel. I'll see what I can find out.This looks awesome. Anyway for me to buy some adapter plates from you???
If he cant get them cut/bent and has the dxf I could do it.I'd have to have Kaleb check with his old HS teacher. He's moved on to college but might be able to see if they can cut and bend another set. He sold one set last year for $50 for the stainless steel. I'll see what I can find out.
I'll ask him, but I doubt he has them since he did it on their equipment.If he cant get them cut/bent and has the dxf I could do it.
I asked him and he could not find it. Sorry guys.I'll ask him, but I doubt he has them since he did it on their equipment.
He found the file!Dang. Well thanks for asking Is there anyone else in here that has the ability to make an adapter for me so I can get adjustable seats? I’m using the Corbeau Seats provided in the kit.
He found the file!
You don't need an account to download it. I believe the download link is in the upper right corner.
If anyone else is able to open the file successfully with usable data and able to save it off let me know. Going to try opening it on a full full version of AC tomorrow but my old version wont open it. Says it was saved as a newer version and draftsight (lame drafting program) just shows a line. My dwg viewer shows the same line draftsight does but when I change the view it shows there more but like the drawing was exploded. Could be just a result of the software the school used for their drafting/NC code.
EDIT: Got it.
I will see if Kaleb can have his HS teacher do up another set. No promises it will happen. Last time he charged $50 for two out of stainless steel.Anyone able to get 2 of these cut for me. PM me with price.
Crossing my fingers. Let me know what you find out. Thanks again.I will see if Kaleb can have his HS teacher do up another set. No promises it will happen. Last time he charged $50 for two out of stainless steel.
