@Torchandregdoc - Ross is talking about this and it's not included in your kit (
https://www.amazon.com/gp/product/B01N1151WH/ref=ppx_yo_dt_b_asin_title_o01_s01?ie=UTF8&psc=1 ). It replaces the shoulder 8.9 bolt that goes into the upper black guide hole on the intake side. It looks like your guide may have broke and they just took it out? It's worth the $15 as the stock shoulder bolt tends to break the guide and things get weird from there.
I would be extremely careful torquing the shouldered 8.9 bolt down to 89 in/lbs. Myself and others have broken bolts off into the block and had to redrill / tap. It looks like you may have one broken off too on the right side of balance shaft upper guide. There are bolts without the shoulders that you could replace with 10.9 (Yellow) but you should reuse the shoulder bolts (with threadlock)
Good luck getting 100 degrees on the TTY cam bolts! I wasn't brave enough but I got close. You could also replace the water pump while you're here (I picked mine up for $35, they aren't typically known to fail though - just cheap insurance).
Green = Dorman 917-954
Red = 11588522 BOLT 8.900 (can be reused)
Yellow = 10.9 M6x1x30mm from Lowes / HD
