JeffsGoblin
Separating the rails from the seats is a pain! I went this way as well, copying ctuinstra. I drilled out the fixed rivets instead of grinder. Passenger rails are slightly different than driver rails. If you look at the top on the passenger rail, there are two bolts in the middle of each rail you don't have to grind off, just unscrew. Unfortunately the driver side only has one set instead of two. I obtained another passenger seat so I could use the extra screw holes for the mounting plate.
