At least that's something I can grab off the shelf there. I ordered brake pads last night and it took the better part of an hour to do it because of all the questions.The powdercoating is looking nice!
For the calipers you can try using VHT's caliper paint, found at Autozone, $9. Various colors. Good to 900 degrees and easy to apply.
I've found that the amount of slop varies between the different vendors from using a variety of them on our Baja SAE cars in college, but had the best fit with the ones from Longacre Racing. If it gets too loose, I can always remove the spud later or pull another shaft from the scrap yard.We tried those style quick releases early on and were aways disappointed as to how sloppy they are.
Fan 1 fuse is good. I've pulled the fan fuses and relays and it still runs as soon as I connect the negative terminal of the battery.Check the 30A fuse for the cooling/fan. Its next to the cooling/fan 1 relay. See if its blown, replace if necessary and test.
My first thought was a stuck relay. Swapping relays didn't change the condition. Removing the low speed relay from the fuse box entirely also didn't change the condition. I'm not sure what the correct resistance values are for the engine coolant temperature sensor (thermistor) but at room temperature, I get about 3k ohms and after a short blast from the heat gun I get about 170 ohms, which indicates expected function regardless of the correct values (i.e., resistance should drop as temperature increases).Is the radiator fan relay constantly getting the signal to stay on? Do you have access to a wiring diagram for your donor car?
We need to find out how the fan is triggered. Probably based on a thermocouple. Is that thermocouple working?
Sounds like you have covered the basics. Is the ECM getting the thermistor value? (need a wiring diagram) and the sending the signal to the fan relay? If the ECM is bad, a simple Arduino project could bypass the ECM... or replace it. Maybe an issue in the wiring harness?I realize that it may not have been clear from the first start video, but the fan is running with the ignition in the off position.
Confirmed.Just double checking, but you used the light blue wire from this connector, right?
First Stage Assembly Instructions
Ground cables Installing the main ground cable Instructions Use the donor ground cable to ground the battery to the battery box. Hold the battery cable against the passenger side of the battery box with the metal tab inside the large hole. Mark the center of the mount hole and drill an 11/32”...dfkitcar.com
I'll check the green wire when I get home from work tonight. As it sits currently, both cooling fan relays and 30A cooling fan fuses are pulled and the fan motor still runs with the key off just as soon as I connect the battery.Did you pull both cooling fan relays to see if that kills the fan. With the relay pulled it should not run at all. Check the green wire coming out of the fuse box (E10) make sure it is not grounded out someplace. That is the trigger wire for the fan relay switched by ground from the ecm.
