Waterdriver
How's it going with your build, any new progress?
Eastwood Dual Voltage gunWhich powder coating kit did you purchase?
This first run has some areas of lighter coverage due to the wire used to hang the parts. They were sitting on the rack after coating just to take the picture, so no grill marks.Are the brackets going to have grill marks on them?
The foam brush leaves bad results. I used the POR15 Caliper paint. I think it is the same as eastwoods. I ended up reducing it with some lacquer thinner and spraying them with a small detail gun. looked so much better.I also brought the calipers inside the house to paint using Eastwood's caliper paint and a foam brush. Kind of regretting that decision because it is both durable and ugly. In retrospect, if I wanted them coated, I should have sprayed Cerakote. No pictures because they're terrible looking.
