Karter2026's City Goblin - 09 LT Donor, PA Build #72
Nilbog
Coolant pipe modification = thumbs up!
Whered you get the piping itself? Did you custom bend it?
Made some more progress. Finished mounting the rear calipers and the master cylinder reservoir. That's when I realized how dusty the car is
I did not like the hose clamp holding the master cylinder together so I made a bracket up. I just have to modify the bolt it will look much cleaner.
Brakes are bled, had one leak at the r. front caliper. Easy fix! I will probably bleed them once more the pedal still feels a little soft. I was able to check all the gears after getting the clutch bleed also. Reverse was the only gear I could not get it into. Another easy fix with a cable adjustment.
Lethalcast
I love the little bracket you made. When I zoomed in on it I noticed you used some ptfe tape on your threads. I would watch for leaks because brake fluid will break it down. I used permatex seal n lock and it's designed for hydraulic fittings and I used it on the master cylinder and intercooler with no leaks yet.
At the point of installing them. The beer won I was tired of looking for the permatex.
Parking brakes are done other than maybe an adjustment down the road.
I ran the cables under the engine. I attached them with a P clamp ate rear of the sub frame. I need one more larger clamp to mount to the bottom of the engine where you can see the uncut zip tie.
