I picked up my stage II this weekend and per Adam some of them having been coming in with the caliper raw (silver) and the clamp portion painted black. I'm going to use the G2 caliper painting kit today or tomorrow on mine.
John
How did you do yours? I was thinking of drilling holes in some angle iron and making some stand offs and bolting them to it, putting them all in a row. Any other advice? Were they pretty clean to start with? Did you dissemble them further?Yep, The G2 kit worked super good. But move pretty fast you have about 1.5 hours and it starts to already get gummy!
Nuker-
Powder coating works great, but the calipers should be dissembled and rebuilt afterwards. This is usually pretty expensive if you have a service do it. The caliper rebuild kits aren't crazy expensive but the G2 kit came in the color I liked and I had heard positive feedback.Interesting.... What about just powder coating them? I'm going to take some of the brake parts to the powder coater today to see what he can do with them. Will they hold up to the heat?
Hate to hear that but I'm sure it's the truth. I actually knew better but was just hoping. I'm not afraid of tearing them apart, I did it on my vette but painter those and didn't care for it, paint still didn't hold up to the brake fluid spill.Powder coating works great, but the calipers should be dissembled and rebuilt afterwards. This is usually pretty expensive if you have a service do it. The caliper rebuild kits aren't crazy expensive but the G2 kit came in the color I liked and I had heard positive feedback.
Some powder coating shops will try to tell you that they can be left together and coated.... run far far away. It can dry out/crack the seals and the system may fail at the least opportune time.
G2 any better than powder coating? Cost for cost powder coat seems to be the way to go other than having to rebuild the calipers.If you go the G2 route, I'd mix it in half batches. At $38 a kit, I'd hate to waste any.
I had a brake fluid leak I did notice for at least a week that was dripping on to my front control arm. It been mouths now since and not any signs of pealing, discoloring at all.Will powder coating hold up to brake fluid better then the g2 paint I was always very care about that so not sure how will it hold up
Did you do the entire caliper (not talking about the mounting bracket) or just the outside of the caliper. I know it's sounds like a weird question, but in the G2 video, the guy did just his outside and I thought that would look silly. And was wondering if a guy would have to buy two sets to cover all four calipers completely.Yeah, I just installed the brakes on the goblin, Sprayed the hell out of them with brake cleaner, taped off the bolt heads and went to town with the little brush. I think it took about 3 coats each. I just went from one to the next by the time I was done with 4th the 1st was ready for a coat again.
Nuker-
Mine are off right now and I can easily do all of them on the bench. Just don't want to run out and then have to buy a whole set just for one more coat or something.If the caliper is mounted it's easier to do just the outside. When I did my Mitsu's calipers I just did the outside and nobody could tell the difference because that's all you see anyways. Saves paint and time.
It's really up to you how much you paint.
