Late model steering wheel control wiring
Steering wheel control wiring.
Ignition voltage
Pink
BCM - X4 - pin F9
Cruise control
Gray
BCM - X2 - pin 61
Info and Return
Dark green/white
Instrument cluster plug - pin 5
Horn
Tan
BCM - X1 - pin 60
Ground
On the BCM near each plug you will find J1 - J4 molded into the BCM housing. I don't know why they use an X for the plug and a J for the plug location.
Nilbog
Ignition voltage
Pink
BCM - X4 - pin F9
Cruise control
Gray
BCM - X2 - pin 61
Info and Return
Dark green/white
Horn
Tan
BCM - X1 - pin 60
Ground
Awesome!! Thanks!
For anybody who wants to light their switches and have them go on/off with the rest of the instrument panel lighting, there is another gray wire that you can use in the same connector. It should connect to BCM - X4 - pin C12.
