Low Offest Wheels
IDRVSLO
Anyone see any issues with running a low offset wheel like 0-20 et? Obviously it will help with inside clearance if going wider. I want some aggressive wheels.
Tinkles
The only issues I could see you running into is the fenders might need alittle tweaking to cover the tire. If you are not running the fenders then I cannot think of an issue.
IDRVSLO
I will only run them to pass an inspection if I need to, then they are gone.
