BaltimoreHokie
Thanks. I think I've got the red wire taken care of. When it comes to the brown there are two which is where my confusion was initially. One for the guages and one for the clutch petal sensor. Both brown with white stripe. I think I need to find where they end up (in the fuse box) so I can try locating which wire does what, then use a tester to see which brown wire i am on. Hope that makes sense.As far as removing the extraneous stuff from your engine harness, it's really up to you. Some people like to remove every little bit that's not needed, and others including me like to leave well enough alone. There is no technical need to get rid of it.
