Perfect thanksView attachment 5365
This is power from the fuse box for your power steering.
I do not have a connector but I do have a terminal connector on the 2005 Cobalt SS this may be causing my starting issue.View attachment 5351
The lower braided wire is the positive that goes to the starter motor when you turn the key to the start position. The starter gets it's ground through the engine block.
Do you happen to have a photo of the lower sensor. Also since you have the same year do you happen to have a photo of the starter smaller wire?It looks like one of the clutch switches is missing. My 05 ss is using both the upper and lower switches. Upper I believe is for cruise control disengage. Lower is for detecting clutch depressed for starting.
Great this helps thanks. If you get an opportunity the starter will help because I plan to track down the cable tonight.This is from my build post for the clutch switches. You'll have to zoom in to see. Maybe down pic then zoom to get in closer.
I dont have a pic readily available for the starter. (At work) Unless someone else posts a photo first, I'll take some photos when I get home from work.
Thanks Chad when I got home tonight I looked through all my connectors and noticed a GPS connector a cut out with a relay. So apparently this cobalt had a security system. Luckily the purple cable was easy to identify because I labeled after cutting GPS and come to find out purple is pretty standard for a starter. I tried getting my starter to work but gave up I think its toast. I went ahead and purchased one on rock auto and also purchased a clutch position switch.There is a purple wire that goes to the starter to engage it. It bolts to one of the small nuts. If the case broke, which many of the do, you might want to consider replacing the starter so it doesn't leave you stranded one day.
Thanks Chad I appreciate it. I actually had a 5% discount totally forgot to plug it in on my order lol. I guarantee it wont be the last part I purchase. I am so close to starting this bad boy! The next few days will be cleanup/organize which is much needed.Rockauto is the way to go. Just keep an eye on the locations the parts ship from. If they ship from two different warehouses, they charge shipping from both.
He is a 5% discount I have that's good until the end of October.
I get 0 on resistance when I test between gray and blackSounds like a short somewhere. Measure the resistance between the gray fuel pump wire on the harness and ground. You should have an open circuit or high resistance.
I unplugged the plug and no fuse popped.I get 0 on resistance when I test between gray and black
If this is only happening when the fuel pump is plugged in would it be caused by the pump ground? I have brought this all the way back to the pedal box which I ground off the powder coat well there.The gray wire is the fuel pump power wire from your fuse box. If you get 0 ohms between that wire and ground, thats why your fuse is popping. You're shorting battery voltage directly to ground when you turn the key on.
If it is only happening with the fuel pump plugged in, then is almost has to be the pump itself. Unplug the plug from the pump and measure the resistance on the same two pins of just the pump. This will help to verify it's just the pump.If this is only happening when the fuel pump is plugged in would it be caused by the pump ground? I have brought this all the way back to the pedal box which I ground off the powder coat well there.
What should my reading be when I’m checking between the 2 wires resistance?
