Mayor West
09 SS/TC 129k miles. Copart stayed as run/drives.
Cranking does nothing, no sounds or clicks. Have tested a secondary known good battery and no changes.
Haven't gotten too much taken apart, I'm wanting to make sure it runs before I do so.
I have the following DTC's: P0808 & P0453. I posted in my build thread but wanted to branch out here to maybe get some more visibility. Briann1177's posted some service manual help and it's greatly appreciated.
Clutch pedal switch is the 3 wire version that sweeps.
I don't have a tech2 so I can only do so much with my multimeter.
I've tested line C/Gray on my clutch pedal sensor to have 4.9v, within spec.
Infested the resistance on wire A (tan) with the ignition off and couldn't seem to get any reading, assuming I was doing that wrong but it could be the reason all of this is jacked up.
Sweeping the sensor reads (to me) fine and varies through the range, however it does spike on the initial movement (from 0 movement to barely any) as in it settles on a number and moves normally. I assumed this was since the sensors out of the car, it was out of the travel range of the sensor but I could be wrong.
I read the fuel pump has a sensor tied into the clutch wire, and being that I have both an evap and clutch pedal high range codes, could it be the ECM?
I think I need to test the wires at the ECM now but I'm very new to this wiring and if anyone has a layout of the sockets I'd really appreciate it! In the mean time I'll search around for one.
