The ignition switch uses screws. I drilled mine all the way through and used a 1/4" bolt and nut.
Had the same issue but it was just because I was low in blinker fluid.Note to self... after wiring up the front headlights and turn signals to find out they dont work, swearing, then rechecking your wiring, swearing, rechecking they wire labels, swearing, rechecking your wiring, swearing, rechecking the wire labels....... make sure you remembered to RE-plug in your blinker lever wiring plugs after you've unplugged them to reinstall your steering shaft e-clip that you forgot to install originally.... WOW (headslap)
Headlights/Blinkers work!
How are others holding their wire routing along chassis tubing? Thinking about the few wires running to the blinkers but also in general. Just zip ties around the wires and tubing? Or creative ideas that wont scrap coating?
