Got the heat exchanger bleed. I ended up taking the hose off the cold side, and put it in a big bucket. Then added a large reservoir to the top of the coolant add port. Put about 1/2 gallon in the reservoir, Manually powered the pump until it was shooting out coolant into the bucket and turned it off. Re-attached the cold side hose. Opened the air port on the coolant add fluid port and continued pumping until coolant also blew out of the air port right next to the fill port.
I have not drove it yet as it has been in the low 50s in the AM and screw that noise! But I'm thinking that it is pretty solid now.
I also got tired of the headlights even with LED lamps they were just throwing light everwhere blinding people, while not putting a lot of light where I needed it.
So what do you do? Make your own!
I got these guys yesterday along with some CREE led chips and boost converter LED drivers. I'm going to work on building some custom LED headlights with projector lens over the next week.
Parts so far
https://www.arrow.com/en/products/cxa3070-0000-000n0hab50f/cree
https://www.arrow.com/en/products/lmh020-hs00-0000-0000002/cree
https://www.amazon.com/gp/product/B01B9VHZNS/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
https://www.amazon.com/Yeeco-Regulator-Adjustable-Converter-Transformer/dp/B00RXJJGE2/ref=sr_1_14?ie=UTF8&qid=1506607686&sr=8-14&keywords=boost+buck+converter
I'm going to modify the projectors to mount the LED chips and design/3d print a case to hold the back side, But I'm going to use the stock lights you can buy with the goblin and just cut the back off to house the LED heatsink.
The LEDs will be slightly under driven at 37volts and should produce around 8k lumens each. Your typical headlights in say a BMW produce around 2700lm on high beam
Nuker-
