Briann1177
The one on the left picture I believe is your MAP sensor. You'll need that. The one on the right looks to be EVAP canister purge solenoid. You can probably go without it.
The one I used was: MOOG K201285 - RockAutoanyone know what moog bushings fit the fe5 control arms. At least that is what I am reading is that the 2008 SS has the Fe5 control arm. I read in someones build thread that they had trouble with the bushing being too small and I just want to make sure I get the correct part number.
From reading, you only use the Bar sensor your tune it designed for. You can't just go change the sensor from stock to 3 Bar and things will be good.Zzp recommends the 4 bar map with their upgraded tunes. Definitely will not work on a stock tune.
